Wiring Voltmeter Gauge on 2007 Road King
I have the Voltmeter, Oil Pressure and Oil Temperature Gauge kits and I'm installing them in the triple mount on my 2007 Road King. Everything about the install is straightforward except the power. The instructions for all three describe how to use a Fuse Block Adapter pigtail and a 2 amp fuse to wire into the fuse block but the fuse block on my '07 FLHR doesn't have an open P&A socket terminal (the P&A socket has a 15 amp fuse and is already wired) and doesn't look anything like the instructions.
Any suggestions? Do all three have to be on the fuse block with the 2 amp fuse or can they be wired into the harness somewhere else?
