sirius radio antenna
I've got mine mounted on the handle bar behind the docking sta.Bought it online http://www.myradiostore.com It's a little mag mount with about 12-15" of coax just for a motorcycle.Came with a little powder coated mounting bracket.I've used it for about 3 yrs. with no problem
i use the Sirius puck type, magnetic antenna. it is attached to the radio under the fairing of my UC. have never had a problem with reception. Have seen a mount that is available where the same antenna mounts next to the Sirius receiver (if it is mounted on the handlebars).
Those little antennas with the magnet backing need to be mounted upon a magnetic surface to allow the antenna to reach its total rated gain. That is why they are so crappy for reception on a plastic or fiberglass surface.
I've mounted mine on a metal plate off the forward end of my radio inside the fairing at the front end of the section over the head light. Most of the reception is not bad until getting into the trees sometimes at a weird direction.
drspencer
12-02-2014 08:31 PM
