Ipod plays out of left speaker only
Old 08-05-2006, 02:03 PM
Kufar's Avatar
Kufar
Kufar is offline
6th Gear
Default Ipod plays out of left speaker only
When I plug in my ipod it only plays music out of the left speaker??? suggestions???? comments?????
Old 08-05-2006, 02:15 PM
Kufar's Avatar
Kufar
Kufar is offline
6th Gear
Default RE: Ipod plays out of left speaker only
I should mention ...I have an 06 Street Glide with stock H/K stereo.
[IMG]local://upfiles/15772/2D53488F715349B0808CDE1A849ADB3E.jpg[/IMG]
Old 08-05-2006, 03:00 PM
rhinoevans's Avatar
rhinoevans
rhinoevans is offline
It normally means it is not plugged in all the way.
Old 08-05-2006, 03:01 PM
wldhogn's Avatar
wldhogn
wldhogn is offline
If your radio plays normally out of both speakers before you plug in your IPod (therefore not being a "setting the balance issue") .. it may be the patch cord you are using. Be sure the end that plugs into the IPod is fully inserted and also be sure you are using a "stereo" patch cord. It should have 2 lines around it on the silver metal part of the plug. If it only has one, it's a mono plug and will only play through one speaker. Just a thought.
Old 08-05-2006, 03:17 PM
dhutchison's Avatar
dhutchison
dhutchison is offline
ORIGINAL: wldhogn
Bingo! It's either not in all the way, or not a stereo cable.
Old 08-05-2006, 03:30 PM
FLRYDR's Avatar
FLRYDR
FLRYDR is offline
[sm=smiley20.gif]
I concur and almost bet it's the patch cord you are using.
FLRYDR
Old 08-05-2006, 05:10 PM
Kufar's Avatar
Kufar
Kufar is offline
6th Gear
BINGO!!! Thanks.....Some times you feel like a nut....some times you don't!
[IMG]local://upfiles/15772/87CD2F98BFC74ECC87995C770D085DE2.jpg[/IMG]
Old 08-05-2006, 05:31 PM
BIGSKY_FLHXI's Avatar
BIGSKY_FLHXI
BIGSKY_FLHXI is offline
So what was the final answer? Didn't get it in all the way or wrong cable. Inquiring minds want to know.
Old 08-05-2006, 05:53 PM
Kufar's Avatar
Kufar
Kufar is offline
6th Gear
Hey... I feel dumb enough as it is...no need to rub my face in it. [8D]
Well last night I was sure that I had pushed the plug in all the way..so today I went out and tried it again with a different plug (with two stripes on the plug) and it worked just fine. Just like WLDHGN said!
2013 RoadKing
Audio Systems
03-24-2017 08:02 PM
Spikehorn
Audio Systems
16
02-24-2017 03:23 PM
hardheaded
05-26-2013 06:23 PM
Herbiedogg
02-15-2008 10:58 PM
hangnman
06-09-2006 04:30 PM
Quick Reply: Ipod plays out of left speaker only
