Bleeding Double Disc Brakes
The ONLY tool you need to bleed front brakes is your hands.
Just need to make sure that the right side of the master cylinder is higher than the left side so that the air bubbles can travel out the ports. Depending on your bars you may have to block the front wheel or rotate the master.
Fill the master and pump, DO NOT let it get low on fluid, after about a minute of pumping you will start to see big bubbles, keep pumping and refilling. The bubbles will get smaller, keep pumping. When the bubbles start getting real small youll start getting some lever pressure.
When the lever pressure builds up to what it should be youll get a little squirt out of the port, if you using DOT 4 make sure to have a rag oround the masre and clean any splash up quick.
