So now I'm feelinglike an idiot. How do the handlebar switches come apart. I removed the top bolt and nothing. This is so frustrating. I can take a classic car down to the last bolt and put it back together easily but this thing is lame or making me look lame!
there's obviously another screw that you missed...
because there are TWO screws holding the switch housings together..
Very sorry. After I was done with the clutch cable I moved onto the switches on the throttle side, not the clutch side. Yes there are two screws holding the assembly together but I just never saw the bottom one. I just started wearing glasses and I still missed the screw on the bottom of the switch assembly. Got that apart and took the throttle and idle cables off. Re-assembly of those to will deffinetely be fun. I measurec the cable adjustments and hopefully the throtle and idle will be close. Sorry for leading you guys on a goose chase. Embarassing maybe. Appreciative of your help.. most certainly. Cheers
Z
