Help! Fairing / clutch cable .....
Old 04-03-2010, 03:54 PM
Zogman's Avatar
Zogman
Zogman is offline
Default Help! Fairing / clutch cable .....
So I'm in the process of removing my fairing from my Ultra so I can paint the inner fairing. I have a manual and I'm going step by step on the dis-assembly. To remove the clutch cable, it's asking me to disconnect it from the transmission which then asks me to remove the exhaust system. Holy crap, do I have to remove the rear tire too to get to the headlight?
So can you tell me if there is a trick to get the clutch cable out of the lever without going through complete bike dis-assembly. Any help would be appreciated. Thanks
Zoli
Old 04-03-2010, 04:01 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Collapse the adjustment, remove small snap ring on the pin under the lever housing, pull the pin, feed the cable thru the slot in the perch, the rest should be self explanitory. The manual is telling you how to replace the cable which you are not doing
Old 04-03-2010, 04:12 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Zogman, gotta ask, but what manual do you have??? HD's has a very detailed step by step description of removing the inner fairing and it doesn't say anything about removing the clutch cable at the clutch end.
Carl
Old 04-03-2010, 04:14 PM
Zogman's Avatar
Zogman
Zogman is offline
I don't know how to collapse the adjustment. The cable goes into the tranny. and I imagine the adjustment is in there. I used an old dirt bike trick and pulled the lever and then pulled on the cable as I released the lever to pull the cable sleeve out of the perch. It works but I would rather know how to collapse the adjustment instead. Thanks
Old 04-03-2010, 04:15 PM
Zogman's Avatar
Zogman
Zogman is offline
I'm using a Clymer manual.
Old 04-03-2010, 04:21 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
The clutch adjuster should be just behind the front fender inside a rubber boot.
Slide off the boot. Hold the cable adjuster (longish looking nut) with a 1/2" wrench and loosen the jam nut (normal sized nut) with a 9/16" wrench........back the jam nut all the out then back out the adjuster nut.
Your clutch lever should collapse.......
Old 04-03-2010, 04:22 PM
Zogman's Avatar
Zogman
Zogman is offline
So now I'm feelinglike an idiot. How do the handlebar switches come apart. I removed the top bolt and nothing. This is so frustrating. I can take a classic car down to the last bolt and put it back together easily but this thing is lame or making me look lame!
Old 04-03-2010, 04:24 PM
hawwk's Avatar
hawwk
hawwk is offline
Zogman to collaspe the cable you have to back the adjuster off. It is in the rubber boot between the tubues in front of the engine. Back off the adjuster then squeeze the clutch lever in to release everything and then you can remove the cable.
If you are going to do work on your bike you might think of getting a HD service manual too.
Old 04-03-2010, 04:26 PM
DPete's Avatar
DPete
DPete is offline
Follow the cable between the frame downtubes is a rubber boot, pull the boot up or down to expose the adjuster. Loosen the jam nut and screw the ends toward each other
Old 04-03-2010, 04:36 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
You shouldn't have to remove the handlebar switches to remove the clutch cable.
If you send me your email addy, I'll scan a page and send it to you.
Quick Reply: Help! Fairing / clutch cable .....
