DOT 5 instead of DOT 4 ?
I went to the dealer to get the fluids, etc for front brakes since I was changing my cables. Told them I had a 09 FLHX and needed brake fluid. Got home and pulled old cables and installed new and realized I got DOT 5 from the dealer and the reservoir and manual say DOT 4... Can I use the 5? I thought that Brake fluid was one of those "don't mix and don't change" I won't be able to get to the HD shop till next week, so if I can use the DOT 5 that would be helpful.
DOT 5 actually has a higher boiling point, and you can use it but you will need to do a full system flush and flush a few more times makeing sure the lines are clear of DOT 4. I have done this with good results on some of my cars, and if its truely DOT 5 it should be a different color too.
