I know how to take it out. I also ordered a new decal for it. How do I get the key cylinder out? I couldnt find it in the manual and according to the local parts counter dude I can't order one without a keyed cylinder.
__________________
2009 Street Glide Pewter Denim ABS, Security.
Blacked out and and BADASS!
Soos 1" Extenders(AWESOME)
Rinehart Slip-ons
Mike pull the hole switch out . When thats done lift the decal off with a small screw driver .the switch will have three tamper proof torx screws. You must remove the screws and keep the barrel key switch UPRIGHT!!!! IF YOU DON'T YOU WILL LOSE THE PINS FOR THE BARREL KEY. Then take some black tape start with the sticky side out then reverse it back to keep the barrel pins in their orignal place.
__________________
2008 Dyna Fatbob SOLD
2009 Street Glide
It is a cover that is black. No risk of screwing up the insides of your switch.
65.00. A little more than having it PC but less risk of a screw up on one of the most important parts of the bike
__________________ Eric
08 V Rod DX
09 Ultra-120r Crate "Plus Motor" S&S roller rockers,Tman 662-1 cams,HPI 58mm TB,D&D Boarzilla,,Rivera/AIM VPC Clutch,Head work by WFO Larry
Build and Tune by StrokerJiK (Jim Kennedy)
2008 SG Vivid Black, ABS, CC, SE Heavy Breather, 12" Paul Yaffe Monkey Bagger Bars, Heated HD grips, Power Commander V, Rush Slip-ons, Advanced Radio Nav, XM Radio
