Removing Derby Cover
Old 04-11-2010, 08:38 PM
shortride's Avatar
shortride
shortride is offline
That's why I relocated the passenger footboard bracket to the top hole on the frame. Now I can get the Derby cover off without removing anything. The 2010 models are already set up that way. It took H-D long enough to figure that out.
Old 04-11-2010, 08:45 PM
soos's Avatar
soos
soos is offline
Originally Posted by Road Ranger
I guess I'm not understanding what you are saying...I have the same model year as you and I just have to take off the passenger foot board to access the bolt you are talking about. My exhaust isn't in the way. Please explain?
The OP stated that he has Rinehart TD's and the exhaust pipe takes a slightly lower route from the rear cylinder down across the passenger bracket. He most likely has the bracket in its upper most position and the pipe is running right across the bolt. This is typical with Rinehart TD's.
Old 04-11-2010, 08:47 PM
SuperAir's Avatar
SuperAir
SuperAir is offline
You may be able to take the footboard off of the bracket and get to it that way. Peel off the footpad and push the pins out of the bracket(do not lose the ball bearing and spring). Or, just loosen up the pipe to get to the bolt, then relocate the footboard.Don't forget to move the other side too
Old 04-11-2010, 08:54 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Long 5/16" ball end allen socket gets in there just fine with Rineharts!
Old 04-11-2010, 09:04 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Just what is a ball end allen socket? Hate to show my ignorance, but here it is in all it's glory. I need to know because perhaps I will then know how to torque an allen head screw.
Old 04-11-2010, 09:11 PM
soos's Avatar
soos
soos is offline
Here ya go...
Ooops on second reading I see the word socket. I missed it the first time.
Attached Thumbnails Removing Derby Cover-220px-allen_wrench_with_ball_end_1.jpg
Old 04-11-2010, 09:21 PM
Route66rider's Avatar
Route66rider
Route66rider is offline
Originally Posted by SuperAir
You may be able to take the footboard off of the bracket and get to it that way. Peel off the footpad.... Don't forget to move the other side too
Thanks, that was the ticket (more or less). I didn't look close enough to realize that the floorboards were adjustable as to vertical positioning. I pulled the pad off and saw that the next time I will be able to remove just the the outer arm & pad and leave the adapter (or whatever it is called) in place. I tried alternate positions, but the particular "Old No. 7" style of derby cover prevents the passenger flooboard from tilting if it is any other location. At least I won't have to mess with the exhaust to do so.
Old 04-11-2010, 09:29 PM
txfxstrider
Originally Posted by soos
Here ya go...
OK, now another question. What is the purpose of a ball end on an allen wrench?
Old 04-11-2010, 09:33 PM
soos's Avatar
soos
soos is offline
A ball end allows you to insert the allen wrench into the mating socket of the bolt at an angle as opposed to a standard "squared" end allen wrench which only allows a straight in insertion. The ball gives you more flexibility.
Old 04-11-2010, 09:37 PM
txfxstrider
Thanks, soos.
Quick Reply: Removing Derby Cover
