The OP stated that he has Rinehart TD's and the exhaust pipe takes a slightly lower route from the rear cylinder down across the passenger bracket. He most likely has the bracket in its upper most position and the pipe is running right across the bolt. This is typical with Rinehart TD's.
I C...Thanks for the explanation. I assumed the Rineharts were the same basic design coming out of the rear cylinder as the V&H duals.
