Largest CI without machining? TC88
Doc's right again...
Forum sponsor Hillside does a good 98" from what I've read here. I wouldn't necessarily rule out a good 95" from Hillside, T-Man, Headquarters, and others that offer 98" as well. Just depends on what you want and how much $$ you want to throw at it.
How do you turn a 88" Twinkie into a 107" without touching the case?
The OP said 88" not 96".
I guess if you're getting technical, the cranks can be changed without "machining" the case.
I venture to say the OP doesn't want to split the case, though.
Enlighten me.
