Help with Wiring on Dragonfly Fairing
Hopefully someone will be able to help an inexperienced one in hooking up an aftermarket Dragonfly fairing. This was a used fairing that was on a 2002 Road King and has a cigarette lighter as well as Kenwood stereo and Sirius Radio. I will be putting it on my 2002 Road King Classic. My issues are where the wires should be hooked it. It has a four-wire pin type quick disconnect like on a truck and trailer type wiring harness.
There are four wires. White, Brown, Green, and Yellow. The previous owner had the yellow and green tied together with the yellow on having a 30amp fuse inline. I called Dragonfly and this is the information I was given by phone.
Yellow & Green - Positive Post on Battery
Brown - Ignition wire (so when you turn on the bike, the radio will come on. Otherwise it will stay so you won't run down the battery).
White - tied into ground.
I can hook up the yellow and green to the battery and ground the white wire. I have no clue for the brown and ignition wiring. Not sure how this would be hooked up.
First does this sound correct? Second, is there any web page or any pictures that could describe this. I enjoy learning different things about bikes through these projects.
Any help would be greatly appreciated!
I had one I picked up used couple yrs ago on a Fatboy. The wiring is right they told you. Look under your dash at wires going to ignition switch and they'll be a red with silver stripe wire. You T splice into it for ignition power. PM me your email address and I have a full pdf of install.
Yellow/Green to battery Positive. Connect fuse
White to Ground terminal of battery.
Brown to Ignition TurnOn (Red w/Silver Stripe)
