Chain case oil
Old 05-03-2010, 07:34 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by Leftcoaster
Dexron ATF in the primary. Cheap, easy to find, and effective.
Don't shoot the messenger here. The June issue of American Rider has an article by Joe Minton on clutches. Minton says that ATF is fine for the clutch plates but a lousy lubricant for the gears and chain.
Old 05-03-2010, 07:44 PM
Lost1's Avatar
Lost1
Lost1 is offline
Does he say why? They've been using ATF in 4x4 transfer cases (chains & gears) for decades and it has worked exceptionally well. I don't use ATF in my primary, I'm just curious...
Old 05-03-2010, 08:29 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
You don't need a fancy oil in the primary, it's not as "hostile" of an environment as the motor or transmission. Fromula+ works just fine.
Old 05-03-2010, 08:30 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
I just re-read the article. He claims that what the chain and sprockets really need is gearbox or differential oil but they would obviously screw up the clutch plates. He recommends the HD Formula+.
RET_SCPO
Oil Archive (no new posts)
14
07-04-2020 08:04 AM
smorris65
EVO
30
07-06-2017 08:37 PM
slvrscoobie
01-07-2017 05:53 AM
bookie boy
03-01-2011 06:12 AM
Rickey
09-22-2010 07:30 PM
Quick Reply: Chain case oil
