09 Roadking Classic with ABS handlebar change
Old 05-08-2010, 06:42 AM
billhawks51's Avatar
billhawks51
billhawks51 is offline
Default 09 Roadking Classic with ABS handlebar change
I want to change handlebars to either reduced reach or heritage style. I read all over that it does not require changing anything else but the accesories book and the website indicate that at least the brake lines have to be changed. Whats going on?
Old 05-08-2010, 09:45 AM
WildBillAce2's Avatar
WildBillAce2
WildBillAce2 is offline
Heritage style here, even swap with no new lines or cables.
Old 05-09-2010, 04:32 AM
Watch Guy's Avatar
Watch Guy
Watch Guy is offline
Default 09 FLHRC and heritage bars
No changes needed. All cables and wires are long enough, but with one caveat. I seem to remember something specific about ABS changes. Mine doesn't have ABS
Old 05-09-2011, 06:21 AM
alyafei's Avatar
alyafei
alyafei is offline
1st Gear
Default 09 RoadKing Classic with 12" Fat Mini Ape Handlebar
I just came from HD dealer.. I asked them what are things needed to change the standard handlebar of my 2009 Roadking Classic to 12" H-D FAT MINI APE??.. they said you must get the following:
- The Handlebar
- Diamondback EL clutch
- Diamondback B/L
- Diamondback B/L (different one and more expensive as well) !!
- Handlebar Cover, Ape, Chrome
- Wire Kit W/Cruise
- Sensor Kit
- Screw
OMG
don't you see it too much?
Old 05-09-2011, 06:24 AM
smokindave's Avatar
smokindave
smokindave is offline
Here's mine, no extensions needed on any cables using Heritage bars.
Old 05-09-2011, 11:56 PM
alyafei's Avatar
alyafei
alyafei is offline
1st Gear
Nice Bike
what I really want is to go backward by Min. 2" and up by 2" as well.. no more... i don't want it to be wider, by the way.. do I need to change all of these? and do you recommend the same handlebar on your bike?
cheers,
Old 05-10-2011, 06:09 AM
Jerry1834's Avatar
Jerry1834
Jerry1834 is offline
I changes a pair on Sat....just need the handle bars...no extra's...go with the Hertiage bars...I think it will give you what you want.
Old 05-10-2011, 09:42 AM
Bingee's Avatar
Bingee
Bingee is offline
I had to change the brake line from the bars to the ABS unit on the right side of the bike when I got the Chubby 508 bars for my '09 RKC. The stock line was just an inch or so too short.
Old 05-10-2011, 11:57 AM
hedgehog1's Avatar
hedgehog1
hedgehog1 is offline
Default ABS no issue
Found great advice and tips in a thread here. Here is a link ( if I did it right). I have 09 FLHR with ABS. No cable changes. There is plenty of slack in the brake line, throttle, clutch.
Since I am still using stock grips I just bought a new one for the left side for around 6.00 rather than wrestle the current grip off the old bars.
https://www.hdforums.com/forum/7502496-post20.html
Old 05-10-2011, 12:50 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
What is dimensional difference between the stock bars and the heritage style on width, height, base width, and pull back. Can you snap a picture with the stock bars set up beside the heritage bars? Thanks, just curious how much difference there is. Wanting to see before I buy if possible. Thanks!!!
Quick Reply: 09 Roadking Classic with ABS handlebar change
