Stock cam markings. Just asking.
On my 05 Ultra stock cams there are 3 marks on each cam. A/1/and a line, the other is A/2/ and a line. Mine did not have any dots to line up on gears or cams. When I have the dots on the cam and crank timing gears lined up the 2 lines on the cams are then across from each other. What are the meanings of the marks on the cams and when the cam and crank gears aligned correctly what marks on the cams should be aligned.
Thanks
Thanks
