Cylinder cut out when hot
The 09 has the heat management feature that you can turn off and on as you desire. It is an option for 08 and 07 that needed to be programed in. If you have an 09 I suggest you take the time to read your owners manual. If your dealer told you it was an option for 09 you might want to consider looking for a new dealer. Take a rain day and read your owners manual it will answer all of your questions about your bike.
You are correct, My 08UC was built in oct 07 and I had to have the ECM flashed for this feature. I have never turned it off since. It comes on every once in awhile when I'm stuck in traffic during the summer. I just leave it on to let the ECM do the thinking for Me.
I have an early 08, it had to be programed (stayed on all the time). I didn't have the ability to turn it off and on until I installed cruse control. Not sure if the its the same with newer models. I live in Las Vegas so comes on a lot. I have had the bike stall a few times when I turn to throttle to disengage it.
Roll (and hold) the throttle forward from 'hands off' idle, watching for a temporary green light on your speedometer ( I think thats where it is) to come on. The light is shaped like a miniature speedometer. To turn off, do same thing and the green light comes on again and turns red.
Ok here's the deal on the 08's
Any touring fbw built after Dec.07 has the ability to engage the cylinder cut off. Page 149 of the 08 Manuel if I remember.
Mine can't be done on the fly. Turn the bike ignition to the start position. Roll the throttle back past closed and hold for a few seconds. If the cruise indicator glows red, it's disabled. When it glows green, it's enabled.
Any bike built before Dec. 07 can get it flashed for free once to enable/disable it.
On the 09's and newer, some have told me that you can turn the system on while the
bike is running. It's not an "On Demand" deal. The bike still has to be in those perameters (279*F at the heads and zero throttle position) for it to kick on.
I still think it's the same as my 08.
Thanks
