Tow Behind Trailer wiring question
Thanks I think I'm going to use the J P cycles plug #300-077 without the isolator. That looks super easy. Do you remove the whole thing and plug the stock plugs back together when you don't need it?
You can just 'hide' the pigtail under the tourpak or saddlebag when you don't need it. No need of removing it. I usually attach the plug to the hitch mount...then it's out of the way.
When you sell the bike, just unplug the 'converter' and replug the harness and is as good as new!!
I've done a bunch of these set-ups in the past.
I have the 2010 street glide and road glide plug and play harness available, no cutting or splicing of your wires. pm me if needed or email me @ brian@asylumcycle.com
If running led lights on your trailer you do not need the isolator. And if by the very slight chance a short happens in your trailer your bike wont get hurt, you will blow a fuse only. I have seen many of the isolators themselves go bad and then people scratching thier heads because they think its something else.
