5 Speed vs 6 speed
5 Speed vs 6 speed
My '04 Electra has the old five speed, however its running great! My question is for the 6 speed folks, what are your RPM's running when you're on the highway doing 75-80? I've read here and elsewhere that folks that have gone with a baker 6 speed, many times regret their decision. Lastly, for the true motorheads if I don't upgrade the transmission to a 6 speed is extended riding with the engine at 3000-3200 rpm (highway speeds 80) a bad thing for the engine?
Thanks again.
Thanks again.
I swapped to the Screamin Eagle 6 speed about 4 years ago. 1st through 5th are the same, at least you can't tell the difference. Only use 6th above 60, and at 80 it's turning about 2700-2800. Planned on keeping the bike for a while, do highway driving, and wanted to lower the rpms a bit, so that's why I went with it. Mileage did improve a bit. 95ci, stage 1, 6 speed and get about 45mpg at 70-75, was getting about 38-40 before. Got about 50,000 miles on it now and no problems at all. If you are in 6th at around 60, need to accelerate and don't downshift, you have no "pull". Other than that it's all good.
Thatzmister2u
05-05-2010 07:00 AM
rfranz1952
03-12-2008 04:13 PM
