Will only start in neutral
it may be the "newbie" thing to do, but the reason I asked, I found myself needing to start my bike to get the he77 out of the way of some idiot and really didn't have time to look for neutral. that's when I found out it wouldn't start in 1st. luckily, I was able to get the idiots attention before he whacked my bike.
thanks anyway
thanks anyway
Start in neutral.....
Your bike should start in gear (with the clutch handle in) - if only for the reasons you say. I think most of us have experienced the need to get a quick restart. I know I have. Forget the other comment. I'd suggest checking your battery terminal connections to make sure they are tight and clean. Also make sure the starter bolts are tight - the starter gets its ground through them. Either of those situations, if not correct, can reduce the available "juice" the starter needs, especially under load. Do you have engine mods? If so, higher compression makes the starter work harder. Starting in neutral is always a good thing to do - except when you don't have time to get to neutral.
thanks anyway
thanks anyway
My first suspect is the battery, it maybe that the thing is not up to the task any longer. I wonder if your using a battery tender during storage periods? If not, its certainly more likely that that component is on its way out, especially if this is a new development.. New Battery, cheap insurance.
BTW, NICE looking ride !
I believe that when you start the bike in neutral, there are fewer gears/shafts being turned that when you start in gear but with the clutch pulled in.
Here's my reasoning - I am a newbie and I used to always park the bike in gear. This was done mainly to stop the bike from inadvertantly rolling. When I would start the bike, it would sometimes lurch forward, even with the clutch pulled in. When I took it to the dealer to check the adjustment, that's where I learned to park in neutral.
I have also noticed that if I stall the bike (which is thankfully getting much less frequent), when I try to restart while in gear, the starter turns VERY slowly.
I see you have a 2008 and wonder if that is still the factory battery. If so, it might be time to get a replacement - perhaps one with greater CCA
If the bike starts easily when in neutral there is little wrong with the electrics. When starting in neutral the starter is only turning over the primary drive plus a shaft in the gearbox. When starting in gear there is clutch drag plus the internals of the gearbox to turn over, which are dunked in 'treacle', so load on the starter is significantly greater.
Checking electrics may improve things, as also using a top quality battery, plus ensuring the clutch is adjusted just right.
