Need suggestions for hiding the antenna mounting studs on tour pack??
Old 06-03-2010, 06:30 PM
bluesmanjesse's Avatar
bluesmanjesse
bluesmanjesse is offline
Default Need suggestions for hiding the antenna mounting studs on tour pack??
OK well I have installed a hidden inside the fairing antenna on my 08 Ultra and now I have these two shiney threaded mounting studs sticking out like a sore thumb on my black tour pack.
What have you guys done to hide those studs? Any pics or suggestions are appreciated.
I did a search but didn't come up with much on this topic mostly just stuff about the antennas brands/etc.
Old 06-03-2010, 06:38 PM
dawg's Avatar
dawg
dawg is offline
Received 2,946 Likes on 1,705 Posts
Depends on your energy level. You can simply put a chrome acorn nut on them. You can simply put a black rubber bolt cap on them. Or, you can disassemble the light bar and remove the studs and fill the holes with flat black hole plugs and you would never know that you ever had antennas on there.
Old 06-03-2010, 07:27 PM
shadowchaser's Avatar
shadowchaser
shadowchaser is offline
I used a black rubber bolt cap like dawg suggested-I'm happy with it.
Old 06-03-2010, 07:31 PM
2WheelGlider's Avatar
2WheelGlider
2WheelGlider is offline
Could you please explain the flat black hole plugs? That's not part of any kit is it? Exactly what did you use?
Old 06-03-2010, 07:34 PM
shortride's Avatar
shortride
shortride is offline
+1 on that suggestion.
Old 06-03-2010, 07:54 PM
dawg's Avatar
dawg
dawg is offline
You can get the hole plugs at Home Depot, Lowes, ACE, etc. Look like pictured below.
Old 06-03-2010, 08:30 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
Got these at local moco!! Im sure all of them stock them!
Attached Thumbnails Need suggestions for hiding the antenna mounting studs on tour pack??-003.jpg
Old 06-03-2010, 09:40 PM
bluesmanjesse
I like that,simple and easy!
Old 06-03-2010, 10:08 PM
bdp's Avatar
bdp
bdp is offline
Local auto parts store, vacumn line female plugs 4 for a $1
Old 06-04-2010, 01:25 AM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
Originally Posted by bdp
Local auto parts store, vacuum line female plugs 4 for a $1
You can get the Vacuum covers in different colors. But Black will just blend in with the Light Bar. And you can get them at any Auto Part store. If when out and some idiot steals the vacuum plug. You can keep extras in the Tour Pak. No big deal or expense.
Quick Reply: Need suggestions for hiding the antenna mounting studs on tour pack??
