Another Garage Door Opener Solution
Old 06-05-2010, 05:31 PM
daytona 1117's Avatar
daytona 1117
daytona 1117 is offline
6th Gear
Default Another Garage Door Opener Solution
Since joining HDForums and reading several (50 or 60) threads on how to incoporate or retro fit my garage door opener I came-up with this idea.
Here is what I did;
I purchased a power supply to add to my Ultra but could not come to grips on making a hole in my side panel. So this is what the power supply from HD looks like.
Take apart a 12V garage door opener.
Take pliers or wire cutters and squish the ends that hold the 12V battery to the garage door opener.
Solder a wire to the remote main button so it will always be on when it gets power.
Here is what the finish product looks like w/o the garage door remote cover.
Continued to the next message......
Old 06-05-2010, 05:42 PM
daytona 1117
6th Gear
Here is the finished product ready to be plugged in
Plugging it in
To activate the garage door opener I turn the Accessory button on and off to send the signal.
Thanks and I hope this helps.
Old 06-05-2010, 05:55 PM
IndyClassic's Avatar
IndyClassic
IndyClassic is offline
nice.......bet I could do the same install with velcro inside the King's nachelle using the to-date unused accessory switch.
Old 06-05-2010, 06:40 PM
malbanese45's Avatar
malbanese45
malbanese45 is offline
Talking
I did basically the same thing except I just tapped the high beam side of the headlight. Flash the highs and door operates.
Old 06-06-2010, 07:20 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Thumbs up
I am not sure which of you two is the most 'flash'! Good work anyway.
Old 06-06-2010, 07:30 AM
deanp1964's Avatar
deanp1964
deanp1964 is offline
I Like it
Old 06-06-2010, 07:56 AM
cajunfla's Avatar
cajunfla
cajunfla is offline
Where does the remote sit? looks like it's laying on the ECM / battery.
Nice job.
Old 06-06-2010, 08:05 AM
cdestuck's Avatar
cdestuck
cdestuck is offline
Can you buy just the male plug with a pigtail that plugs under the seat without the 12 volt recepticle?
Old 06-06-2010, 11:14 AM
daytona 1117
6th Gear
Nice job.
I found a spot in front of the battery box and twist tied the wires so it would not move. I would have a picture but my camera will not fit in the space.
Old 06-06-2010, 11:16 AM
daytona 1117
6th Gear
Not sure if you can. It would be a good question for a HD dealer.
Quick Reply: Another Garage Door Opener Solution
