hard to crank when hot
Old 06-09-2010, 02:15 PM
flhx103's Avatar
flhx103
flhx103 is offline
Stage I
Default hard to crank when hot
Ive got a 2007 streetglide with a 103 kit and s/e race tuner and when its hot from running it is very hard to start it really fights the starter , any ideas maybe compression releases ?
Old 06-09-2010, 02:28 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,796 Likes on 8,396 Posts
The battery may be nearing its end of life.
Compression releases help quite a bit with the stock starter.
A heavy duty starter would be better.
What is your compression ratio?
Old 06-09-2010, 05:00 PM
saw*me's Avatar
saw*me
saw*me is offline
Ditto. Test battery first. When they're hot they'll kick..... (start)..... hard. Releases were an afterthought for me too. The thing runs so good I can't bring myself to tear it down again.
Tom
Old 06-09-2010, 05:13 PM
bagman1's Avatar
bagman1
bagman1 is offline
By any chance you running a 255 cam?
Old 06-09-2010, 05:25 PM
twistr's Avatar
twistr
twistr is offline
Old 06-09-2010, 05:42 PM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
Bet you, that is his problem!!! SE255 cams without compression releases = a no,no!!! You need a great tune, with a good tunning device, & comp releases, to help with the hot starts with that early intake close cam!!!
Old 06-09-2010, 07:24 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Get the SE compensator upgraded all problems be gone and there is no other way.
Old 06-10-2010, 06:37 AM
onionfmr's Avatar
onionfmr
onionfmr is offline
I had this problem too! First, as said above, check all your electrical connections and battery strength. Looks like you have the SERT. First thing I would try is adjusting the values in your Cranking Fuel Table in the higher temperature range. That made a big difference on two of my bikes. I went for the absolute fix and also did the SE Comp and Harley HO starter on my 103 with 255 cams. Hot start problem fixed and it seems to shift easier.
Old 06-10-2010, 07:33 AM
bagman1's Avatar
bagman1
bagman1 is offline
Man what a god aweful expense to fix a problem. I have a 510 cam for 25k miles with out ever an issue, amd from what ive seen here on the forum ive got better numbers than almost all the engines with a 255 cam.
Old 06-10-2010, 11:07 AM
iclick's Avatar
iclick
iclick is offline
The SE255 are fine with stock compression but some with the 10:1 flat-top pistons (Stage II) have hot-start problems like the OP.
Quick Reply: hard to crank when hot
