Need PCV Map Comparison Tool Here It Is
I created a conditionally formatted spread sheet for compairing the PCV maps here is the link to download it http://www.box.net/shared/it23fgcv8f
1. Highlight and copy the tables from the PCV software of the first map and paste them into the first map in the top two tables in cyl 1 and cyl 2 respectively in the spread sheet.
2. Highlight and copy the tables from the PCV software of the second map and paste them into the second map in the second lower tables in cyl 1 and cyl 2 respectively in the spread sheet.
(you just have to click on the first cell in the tables to paste them as the colum and rows are not locked)
Then in the 3rd or bottom tables in the spread sheet will show the difference of change no input is needed in these fields they auto populate.
Also the top two, and second lower two tables will keep the cells that are the same to be green in color. The cells that have changed will remain white.
The bottom tables that shows the change in numbers the green fields are the change which directly reflects a cut out of the fields above them from the green and white coloring.
You can use the tool to compare any of the tables Target AFR, Trim, Fuel Table and ignition.
Let me know if you guys come up with any ideas on modifying this thing as I just put it together to see what the hell was going on with my auto tune.
