Old 03-17-2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Having issues with your audio equipment? The first post gives great tips on self-diagnostics in order to help pinpoint your issue. Forum members list their issue and solutions that worked for them.
Read the full discussion below to find out if your issue is listed and what helped forum members fix the problem.
Print Wikipost
Self-Diagnostics for Harman Kardon radios
Old 06-29-2010, 09:47 AM
Rigid113's Avatar
Rigid113
Rigid113 is offline
My 07 road glide has a problem with the volume. It was shooting up to full blast at random times now it does it less but I can't turn the volume up just down. I have the following codes...
B2008 Handlebar switch shorted low
B2009 Handlebar switch stuck or open
What would your next step be? I just got this bike it does have chrome switched installed.
Old 06-29-2010, 07:34 PM
Rigid113's Avatar
Rigid113
Rigid113 is offline
I think I figured it out. After visiting the local dealership the service dept told me I needed a new audio switch. They didn't have one in stock so I came home. I started to take the controls apart and found that the wires were pinched against the bars. I realigned the wires with the dimple and all appears to be good now. I just bought this bike last week sol I was unsure what had been done to it in the past.
Old 07-01-2010, 04:41 PM
scooterman01's Avatar
scooterman01
scooterman01 is offline
Stage II
2006 Street Glide radio turns off and back on again by its self
Old 07-06-2010, 12:55 PM
rgm's Avatar
rgm
rgm is offline
What exactly does this error code mean:
Does it mean my low beam switch has shorted out??????
Old 07-06-2010, 08:07 PM
j.jones's Avatar
j.jones
j.jones is offline
6th Gear
I have a 09 streetglide my radio needs to be replaced . The code can up b2007 .I am being told i will get a refurbished not a new one .has this happen to anyone else
Old 07-07-2010, 08:24 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Post your individual problems as new threads. You'll get more views than posting replies in this sticky thread, and more likely to get an answer to your questions.
Carl
Old 07-10-2010, 05:24 PM
18BKLR's Avatar
18BKLR
18BKLR is offline
Find it a lot easier to pull the HK out and sell it on Ebay. 800-1000 bucks. Spend that money at biketronics and your problems are gone, and you get a way better stereo in the end. Just my opinion
Old 08-01-2010, 11:29 AM
Meatloaf-sc's Avatar
Meatloaf-sc
Meatloaf-sc is offline
Default thanks
great post thanks
Old 08-01-2010, 08:38 PM
SKY NET's Avatar
SKY NET
SKY NET is offline
6th Gear
I have a 09 street glide , when you turn the ignition on my hk displays (radio not calibrated) ?
Old 08-02-2010, 09:02 PM
Xkikbxr's Avatar
Xkikbxr
Xkikbxr is offline
4th Gear
Anyway to diagnose a radio on a 2000 FLHTC? I had the radio and amp and volume control on the hadle bars replaced in 08 because of a short in the system. It was replaced unde extended warranty thru the dealer. It was a direct OEM replacement supposedly but I think it was actually a refurbished radio and amp. Anyway the new symptoms are that the front and back left sid espeaker is cutting off and on I get a lot of satic when hitting bumps in road. Any thoughts would be appreciated.
Thanks,
Quick Reply: Self-Diagnostics for Harman Kardon radios
