2007 Ultra Wobble - Brace ?????
Guys, I have a 07 Ultra Classic and I am noticing a slite wobble when riding especially on hard curves on the free way. It also feels like my front wobbles when riding.
I have checked my air pressure to ensure that it is correct, and both tires are normally filled to 38 to 40 PSI... I have the Harley Davidson white walls (wide).
Have anyone noticed this on their bikes and if so did you switch to a brace like bagger brace.
What was the difference in the the ride before and after you installed it. Is it worth getting..
Thanks for your input..
This topic comes up every week. Check previous threads. Search on 'wobble' or 'brace'....
Try this thread and this one.
I have an 07 Ultra that has 35K miles on it. Yes I have experienced the wobble as you describe. I no longer have an issue with the wobble.First : I switched from the D402's that came stock on the bike to the Dunlop E3's. Second: I changed the shocks on the rear to Progressive 412's 412-4019 is the part number for the shocks I used. I put 12.5 inch shocks on in place of the 13 inch stock shocks.
The changing of the tires to Elite 3's made a noticeable difference in reducing the wobble. When I changed the rear shocks that reduced the wobble effect even more.
There was one sweeper curve that the wobble would occur at any speed above 60 mph. I can now go thru that same sweeper curve at 70 mph plus and the bike is steady.
I had looked at the various braces, but didn't want to spend the money. I spent the money on better handling and riding tires and also shocks to make the ride more comfortable. My next project is to now do something with the front end suspension.
David
David
Try this thread
Try this thread
David
David
Terry
Mine's an '08 which has the head stay that the '07 does not have. The head stay helps with the wobble issue a little but after installing the "Bagger Brace", I have noticed a huge handling improvement especially when you hit a bump while going through corners.
Adding tires does not do anything for keeping the transmission centered in the frame which is what the bagger brace does for your bike.
There are other ways to help with this such as nylon bushings in lieu of the stock rubber bushing mounts but for $275 and thirty minutes of your time. The Bagger Brace does what it claims.
Chassis alignment is the first step. If the motor,transmission and swingarm are not in alignment with the frame (which 99% of bikes are not) then the rest are just bandaids. Once everything is in line then the addition of a brace, good tires and good air pressure in the shocks will make the bike will handle well.
