front axle torque spec
Old 07-10-2010, 09:44 AM
06strglide's Avatar
06strglide
06strglide is offline
Default front axle torque spec
anyone know the spec 08 FLHTCU
Old 07-10-2010, 10:42 AM
06strglide's Avatar
06strglide
bump anyone?????
Old 07-10-2010, 10:44 AM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Here are the specs for an 06 Ultra without ABS if it helps you;
Axle nut/50-55ft-lbs
Axle holder nuts/132-180 in-lbs
Lower caliper mounting bolt/28-38ft-lbs
Upper caliper mounting bolt/28-38ft-lbs
Old 07-10-2010, 10:48 AM
Moe55's Avatar
Moe55
Moe55 is offline
Don't know about 08 but 05 spec.
Axle nut 50-55 ft-lbs
holder nuts 132-180 inch pounds
caliper bolts 28-38 ft-lbs
Hope that helps some?
Old 07-10-2010, 11:01 AM
06strglide's Avatar
06strglide
yea I know what the older ones are. 08 has a larger nut on the axle.
Old 07-10-2010, 11:34 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
60-65 ft-lbs.
Carl
Old 07-10-2010, 01:05 PM
dawg's Avatar
dawg
dawg is offline
Received 2,938 Likes on 1,701 Posts
axle nut 60-65 ft lbs
Old 07-10-2010, 06:10 PM
06strglide's Avatar
06strglide
Thanks
Coastal CVO
09-14-2017 05:27 PM
thoner7
01-27-2014 12:52 PM
man4mopar
05-29-2009 10:35 AM
myking
01-13-2009 06:19 PM
Feisty 1
10-05-2006 10:04 PM
Quick Reply: front axle torque spec
