Rear squeak
Old 07-15-2010, 06:43 AM
07-roadking's Avatar
07-roadking
07-roadking is offline
2nd Gear
Default Rear squeak
i just purchased a 07 road king a few months ago and within the last 2 weeks i have noticed a squeak coming from the rear only when the driving they put a new belt on when i purchased it. any ideas?
thx
Old 07-15-2010, 07:31 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
Its probably the brake pads squeaking against the rotors. If it stops when applying the rear brake then that is most likely the problem. About the best way to repair it is to replace the pads. Or live with it. You also could try removing the pads and sanding the pad surface to get rid of the glazing. But if they got oil on them then replacing is the best route to take.
Another possibility is a loose rear sprocket. Check those 5 bolts and make sure they are TIGHT. If even one is loose then at minimum you need all new bolts and maybe even a new sprocket if the holes are oblonged.
Old 07-15-2010, 07:46 AM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Check the rubber exhaust mount. They get dry and will squeak like crazy.
Old 07-15-2010, 07:50 AM
rocknrod's Avatar
rocknrod
rocknrod is offline
Yep - thats the ticket.
Old 07-15-2010, 09:21 AM
07-roadking
2nd Gear
i dont think its the brakes because it still does it when i apply them. i will have to look at the exhaust mounts , the only other thing i can think of is the belt but is new , if it is the exhaust wouldnt it also do it when idleing it only does it when driving?
thx
Old 07-15-2010, 09:30 AM
valvestem's Avatar
valvestem
valvestem is offline
thx
The new belt may be rubbing on the sides of the rear pulley guide. I suggested some HD Poly-Oil a while back for a fellow that had the same symptoms. Applied on the SIDES of the belt, it will take care of the squeaking if that is the cause. You can tell if it is by, put rear wheel off ground, bike in neutral, move rear wheel around, listen. My FLHT has been doing the squeak since about 2006 when I went on a dusty dirt road for about 10 miles. I put the Poly-Oil on it, it goes away until all the oil is gone, then I put more oil. BTW, it really is not an "oil" it has the consistency of cottage cheese, but is clear.
Old 07-15-2010, 11:49 AM
07-roadking
2nd Gear
i just oiled the exhaust mounts and found a loose nut for the rear bags. i will see what happens on the ride home
Old 07-15-2010, 12:57 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
The rubbers for the rear exhaust are about 2.00.Mine seems to need them every 15,000 or so.
Old 07-16-2010, 06:19 AM
07-roadking
2nd Gear
no luck it must be the wheel ,belt or pully
Old 07-21-2010, 03:01 PM
07-roadking
2nd Gear
i pulled out the exhaust mounts again and sprayed them with wd40 and i think the squeak may be gone , i will have to ride it for few more days to see what the results will be
RadRodriguez
04-18-2018 03:48 PM
Fuzzy1950
03-28-2015 03:44 PM
Burstbucker
Wheels/Tires
03-20-2012 09:10 PM
bdejong11129
04-20-2008 04:33 PM
Navychief
10-01-2007 09:05 PM
Quick Reply: Rear squeak
