anyone install clutch cable 38649-08
just installed longer clutch cable on my 2010 FLHX after putting on pullback bars. This OEM cable was 4 inches longer than stock but was $34.00 instead of buying the diamnondback cable for $100.00. however this cable is also longer between the clutch cover and the adjuster than the stock cable so getting the adjuster to fit in between the front down tubes like stock is not possible. has anyone installed this cable? and how did you route it so the adjuster fits nicely and looks good.
I'm curious as to where the adjuster ends up when you're done.
I'm thinking about going with Khromewerks +2 sweepers and they recommend the 38649-08 cable for my bike also.
Does the adjuster end up 4" higher along the frame tubes than stock?
Never thought about this until you brought it up.
Thanks
Mick
Thanks
Mick
Same here just installed +6 magnum black pearl and the adjuster landed right were the old one was. I installed a +8 Drag cable and the top of the crash bar was were the adjuster wound up.
ConeMagnet
09-03-2014 07:54 PM
97CMC
01-18-2010 10:20 PM
