New Wood Knight Prowler TW-555 Cams
Old 07-23-2010, 01:45 PM
bald1der's Avatar
bald1der
bald1der is offline
Love the pic's.
Old 07-23-2010, 01:55 PM
Avalanche_Mutt's Avatar
Avalanche_Mutt
Avalanche_Mutt is offline
Jamie,
You can use my limited to do testing if you want!!
Old 07-23-2010, 02:06 PM
USA1HD1's Avatar
USA1HD1
USA1HD1 is offline
Originally Posted by davewear
love to see the results of tw6-6 vs tw6-6 with 4 deg advance in a stage 1 bike no comp added.
I have the second of the above mention here is my set up.
2008 FLHX
Rinehart true dules
SE heavy breather
SE Tuner
Woods tw-6 -6
4 Deg advance gear
82 - HP 96 - TQ
Old 07-23-2010, 02:09 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,104 Likes on 1,339 Posts
Doing back to back test between TW6-6 and TW6-6 w/+4 gear on our 2010 Street Glide in August. Will surely post results here and on our website
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 07-23-2010, 02:14 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Originally Posted by Avalanche_Mutt
Jamie,
Thank you for the offer, we may purchase a 103" bike for testing. I'm waiting to see tuesday what they are doing for 2011
Old 07-23-2010, 02:44 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
Subscribed... Curious how this cam performs over the 255's in a 103 STG 2 kit, stock non-cat 09 head pipe and Jackpot Dyno Tuned mufflers...
Old 07-26-2010, 01:56 PM
bradsULtd's Avatar
bradsULtd
bradsULtd is online now
Originally Posted by fuelmoto
For these cams we wanted slighly more lift and Bobby added slighly more duration as well. When Bobby speaks I certainly listen, this good ol' boy has probably forgotten more about cams than I will learn in a lifetime. We are expecting similar numbers to the TW6-6 which is an awesome cam, the extra lift and additional 2 degrees of duration should make slighly better numbers especially if you have increased compression. The new TW-555 cam should work especially well in the 103 Limited.
Here is a cool picture of Bobby Wood's tuning a Blown Chevy big block in 1965. This was the year the "new" big block platform was released as the 396 replacing the 348/409. Also a picture of one of Bob's NHRA Funny cars.
Jamie...could you give some detail around the above quote in bold? Also I'm assuming you will be posting dyno run charts showing before and after adding the TW-555 cams...thanks.
Brad
Old 07-26-2010, 02:06 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Brad
I was referring to the larger displacement of the 103" models which should really benefit from the extra .045 lift of the TW-555 compared to the TW6-6, which is already an awesome cam upgrade in these models.
Old 07-27-2010, 02:12 PM
davewear's Avatar
davewear
davewear is offline
2008 FLHX
Rinehart true dules
SE heavy breather
SE Tuner
Woods tw-6 -6
4 Deg advance gear
82 - HP 96 - TQ
do you have a chart for that? like to have a look at the tq curve, thanks.
Old 07-27-2010, 02:19 PM
jeff.georgalas's Avatar
jeff.georgalas
jeff.georgalas is offline
Here's mine w/o the 4 degree advance.
Quick Reply: New Wood Knight Prowler TW-555 Cams
