HD LED Oil Dip Stick
Old 09-08-2012, 09:06 AM
jerryleon's Avatar
jerryleon
jerryleon is offline
Had mine for two years now and had no problem..don't know how accurate the temp is but oil level right on.....
  #42
Old 09-08-2012, 09:07 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Originally Posted by CrusingHarley
FWIW,
I was going to pick up one last week and the parts guy at my HD shop talked me out of it. He said they have to many problems with them.
I have two of them. One on each bike. Never had a problem. As far as accuracy, the oil level is accurate. I have never te3sted the temp side, but it sure seems to be close.
  #43
Old 09-08-2012, 06:44 PM
DutchHawg's Avatar
DutchHawg
DutchHawg is offline
I had one of the older ones in my 01 Ultra with no problems. When I got my 10 Limited I had to get a new one because this one screws in. It worked fine for about 2 years but is now reading high oil. I would check it on a cold engine, which they say not to do, and it was down a little. On a hot engine you could not tell the level. I just changed the oil and to my suprise there was only 3 quarts not 4, including the oil filter. Has anyone heard anything about false high readings and maybe a way to clean them to make them return to accurate? Thanks a lot, and Limiteds do have oil coolers.
  #44
Old 09-08-2012, 07:06 PM
NOLAMike's Avatar
NOLAMike
NOLAMike is offline
I've had one for three years and I'm still on the original battery. I've compared the level reading to the original dip stick and it is right one. I really like being able to check the oil without scalding my fingers and dripping oil on stuff. As to the rain comments it's been washed 100s of times and gone through countless Gulf South thunderstorms and I've not seen any signs of moisture intrusion.
Maybe I just got lucky with this unit.
  #45
Old 09-08-2012, 07:33 PM
oneballz's Avatar
oneballz
oneballz is offline
Don't you think if it was important HD would have one from the factory?
Save your money and buy some spikes or skulls for your bike instead.
StevieRay59
Milwaukee Eight (M8)
14
12-30-2017 04:12 PM
Jessie
08-02-2012 09:14 AM
rootbeer bob
12-19-2011 10:21 AM
pauletich
05-18-2010 07:06 AM
Bagger_Dave
02-18-2007 10:52 AM
Quick Reply: HD LED Oil Dip Stick
