Currently performing 25,000 service on 08 FLHR. My maintenance schedule says it's time to replace Fuel Tank Filter (part# 61011-04A). Ok, no problem. After following Service Manual instructions it says I need a HD48646 Fuel Tank Cam Ring Remover/Installer to remover the assembly to get to fuel filter. Where can I purchase one? Thanks.
Have you tried to remove the cam ring by hand? I recently bought a secondhand tank and have everything I need to install it except that ring! My local dealer has never stocked one, but I will be trying my best to get away without a tool. I understand the tool costs around 70 bucks.
Is this something only on the newer touring models. My 02 is just getting there 20+ (I just got it last year) and I checked my manual and it seems to be all normal tools.
Location: Longwood, Florida, Seminole County, United States of America
Special Tool my ***. I remember doing the same thing with a Car Fuel Tank. Where the Fuel Pump used to be in the Fuel Tank. I would lower the Fuel Tank and I would use a wide tip screw driver and a rubber mallet and "tap tap tap" the locking ring off.
I will be doing the same next month. I'm at 20,115 Miles now.
