Fuel filter change pics 09' touring
Old 08-08-2010, 10:40 AM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Originally Posted by strtarrow
I love your blunt object picture, Funny!!!!
he hee I put that for Dawg. The tool or a home made one like it is superior to the hammer and blunt object around nice paint. Tried a blunt punch on assembly had to hit awfully hard so I quit and borrowed the wrench from the dealer, had it on in 5 seconds without beating the chit out of things
Old 08-08-2010, 10:57 AM
Navy Mustang's Avatar
Navy Mustang
Navy Mustang is offline
I'm about to do this on my '09 in 1,500 miles. Thanks for the visual, always helps. I'm hoping I'm able to get the locking ring back into place using a blunt object...
Old 08-08-2010, 12:46 PM
Jerry1834's Avatar
Jerry1834
Jerry1834 is offline
You can change the filter without removing all from the tank. Just get it out so you can disconnect one hose (let the pressure off) and then remove the horseshoe clip. Take the halves apart and remove the old and put the new in.
The tool can be made out of SCH 40 PVC....Trace a copy of the ring and make it up later....Hope this helps.....Jerry
Old 08-08-2010, 03:34 PM
happyhooligan's Avatar
happyhooligan
happyhooligan is offline
[quote=Jerry1834;7115265]The tool can be made out of SCH 40 PVC/quote]
What size pipe?
Old 08-08-2010, 07:30 PM
Jerry1834's Avatar
Jerry1834
I'll have to check...My buddy made one up....Think it was 5" i.d.
Old 08-08-2010, 07:46 PM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 69,677 Likes on 21,254 Posts
Good Job!! Thanx for the pictorial! What tipped you off that you needed to? change it other than milage? Was it hesitating, or?
Old 08-08-2010, 08:00 PM
PhilM's Avatar
PhilM
PhilM is offline
Gotta love that "Blunt Object"!
Old 08-08-2010, 09:12 PM
DPete's Avatar
DPete
DPete is offline
No it was running fine, the manual says change @ 25K. Was thinking about it in desolate Nevada last trip so I changed it. $13 and a little time is worth it to me. Good idea Jerry on the PVC to make a wrench, will look into that.
r8rs4lf's Avatar
r8rs4lf
r8rs4lf is offline
Originally Posted by DPete
Today was the day, I took Dawgs advice and used a blunt object on the cam ring.
Can you tell me why you decided to do this? I have an '09 and it seems a bit premature to be changing this. Did you have a problem? I have an '09, reason why I'm asking.
Nevermind, I should have read the whole thing first.
Old 10-13-2010, 03:54 PM
y2kflhr's Avatar
y2kflhr
y2kflhr is offline
I am going to try and do this over the weekend, any other sage advise?
I don't think my dealer will lend me any tools to get this thing back on, so I am going to have to bang the cam back on or go to home depot and get some pvc, I just am not sure on the pvc once I trace out the notches how would I grab it to turn? Thanks
Quick Reply: Fuel filter change pics 09' touring
