Fuel filter change pics 09' touring
You may not find the right size PVC at Home Depot etc. You need something 5 1/2 OD and 4 1/2 IS.....I got some from a junk pile in a plumbing supply store. It was some type of coupler.
Where the teeth are... there was a groove on the pipe...probably for some type of O ring....I rounded it out to 5" IS.
Hope this help.
Hope this help.
thanks, I got it off last night, seems like it will go on with a little elbow grease, I will be getting the filter today, that gives me some time to get the pvc before the weekend if I have to, I was able to get to the filter without disconnecting any hoses by gently moving some hoses around inside the tank
btw. hard to call a dealer a stealer when they lent you a tool that would have cost 100 bucks, and don't make me defend dealers!!!
edit: I found these at my company 5" ID, 5.5 OD cores for web printing
I am going to try and do this over the weekend, any other sage advise?
I don't think my dealer will lend me any tools to get this thing back on, so I am going to have to bang the cam back on or go to home depot and get some pvc, I just am not sure on the pvc once I trace out the notches how would I grab it to turn? Thanks
I took a ball peen hammer and a blunt object (wrapped in a towel), I put a little anti sieze on the bottom of the cam and lightly tapped it and its on bing bang boom.....
the whole job took about 45 minutes including waxing under the tank panel....
be careful putting the gasket over the filler it wants to pull up, a little spit fixed that right up.
