iPod interface
#142
#143
#145
#146
Boom Audio Nav Module
I have been reading through these posts, and need some help. I installed the Boom Audio Navigation Interface Module, with the IPOD Navigation Connector, and the Zumo 660. The audio wire is connected from the NIM to the AUX on the front of the radio. After installing all of these I can not get the zumo to interrupt the radio during audio instruction from the zumo. Any suggestion? Thanks.
#149
The one thing that I did notice in the IPOD/Navigation Connector instructions was:
IN USE
the speaker selector switch should be in the "a" (illuminated) rearward position to hear navigation prompts over the vehicle speakers.
I think they are referring to the rocker switch on the lower dash. But I do not have one.
IN USE
#150
Second...make sure your instructions are REV 2010-09-14!
Third...the audio connection from the NIM has two possible configurations. These are the Zumo IS being used as an audio source or IS NOT being used as an audio source. See page 3 of the instructions, step 8.
Your description does not say which way you have it connected...but sounds as if you are planning to use the Zumo as an audio source since you mention using the AUX port...and in that configuration you must use the supplied 'Y' cable. But using the 'Y' cable presents another problem in that you are left with two female connectors for the last connection. You need to purchase a 3.5mm 'Stereo' Male - Male adapter cable.
Steve
