Wind deflector for road glide
Old 08-11-2010, 08:34 PM
elauee1's Avatar
elauee1
elauee1 is offline
Default Wind deflector for road glide
Has anyone installed the wind deflectors on a newer road glide and do they work.
Old 08-11-2010, 08:48 PM
emwolb's Avatar
emwolb
emwolb is offline
are you talking about what's called the fork air baffle? if so, you may know that they were on all roadglides till i think 07 or 08 and then they no longer came with them. it's the steel one that screws onto the rear of the lower triple tree. if that's the part you're mentioning, then yes, they do work.
Old 08-11-2010, 09:22 PM
SteveO's Avatar
SteveO
SteveO is offline
I put one on my 08 Ultra SE3 when I removed the lower fairings, and I did not like it at all. I find it directs hot air up the front sides of the tank area onto your face at low speeds in summer and same problem with cold air in winter.
Old 08-11-2010, 09:25 PM
nedster's Avatar
nedster
nedster is offline
they came out with deflectors that clamp on to the crashbar in front of the tank...seen them on the SERG
Old 08-11-2010, 10:08 PM
elauee1's Avatar
elauee1
elauee1 is offline
Yes they r the plastic clip on ones
Old 08-12-2010, 08:47 PM
SPARKY01's Avatar
SPARKY01
SPARKY01 is offline
put them on my 09 and rode about 200 miles last sunday . have a windsplitter on so i am getting a lot of wind but no buffeting @ 70-75 mph. real test will be when i put my x-stream back on in the fall. worth 30 bucks imho....ride safe
Old 08-12-2010, 08:54 PM
twodollarbill's Avatar
twodollarbill
twodollarbill is offline
My dealer has a CVO on the floor, there was a set of the deflectors in bag in the tour pak.
They must want you to put them on if you go out for a ride without the lowers.
Old 08-12-2010, 09:30 PM
BadX's Avatar
BadX
BadX is offline
lp put a set on his bike and said they work great. I called my dealer today and ordered a set, won't get them till next week sometime but lp is a straight shooter and if he says they work then they do.
I put the old air baffle on my sg and couldn't tell much difference but I put my hand in the area that these go and could tell that air comes up from that area so I am pretty excited about trying these out.
Old 08-12-2010, 10:06 PM
elauee1's Avatar
elauee1
elauee1 is offline
I installed them going to try them out sat I also have a wind splitter
Old 08-13-2010, 06:18 AM
RangeRat's Avatar
RangeRat
RangeRat is offline
I like 'em well enough to leave them on. I happen to use the Kel Tek belt clip on my little .380. I usually just leave my t-shirt untucked with my piece hooked onto the belt, barrel stuffed into my front pocket.
When I got the new RG I noticed that my t-shirt was being sucked toward the fairing so hard that it was stretched tight on the sides and I was printing, bad. Not any more with these flaps installed. My T just flutters some in the breeze that seems a lot more like my old Road King now.
WTA: Using a Klock Werks windshield too.
Quick Reply: Wind deflector for road glide
