Oil in a HD Premium Oil Cooler -Part # 26155-07
Old 08-26-2010, 08:53 PM
boston138's Avatar
boston138
boston138 is offline
Default Oil in a HD Premium Oil Cooler -Part # 26155-07
When doing a oil change, how much extra oil do you add to a 2008 Ultra Classic with a oil cooler or does the dirty oil in the oil cooler ever drain out?
Old 08-26-2010, 08:58 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
No, it never drains out during an oil change due to it being lower than the adapter and the thermostat being closed during the oil change.
Old 08-26-2010, 09:02 PM
Jinks's Avatar
Jinks
Jinks is offline
Enough to bring the level up to full when hot...............
Old 08-26-2010, 09:08 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
There is not enough in there to worry about during an oil change. What there is gets filtered when up to temp. I have had no problem on mine and the oil looks new for quite some time after the oil change.
Old 08-26-2010, 09:58 PM
iclick's Avatar
iclick
iclick is offline
Guntoter is right that there isn't enough in the cooler to worry about. I use 3.75 qts. in my '07 with filter and it shows full when hot.
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
There is so little oil in the cooler core you would not have to think about it. Ask me how I know--
Aw, OK I'll tell you. I overfilled my sump after installing a cooler thinking it would hold about 1/3 qt.--silly me....
Hey you know those turkey baster suction thingies with a bulb on the end? They work very well for sucking oil back out through the fill hole......
Old 08-26-2010, 10:03 PM
BLK08ROCKERC's Avatar
BLK08ROCKERC
BLK08ROCKERC is offline
Awww man that sucks! That sounds like something I would do!
Old 08-27-2010, 10:12 AM
boston138's Avatar
boston138
Default Oil cooler
Thanks for the information. Mike
JJHOG
03-08-2012 01:43 PM
watercop
04-27-2011 08:32 PM
leeinmemphis
08-24-2009 10:04 PM
cabowabodude
04-20-2009 02:41 PM
Capt Jim
07-16-2008 04:02 PM
Quick Reply: Oil in a HD Premium Oil Cooler -Part # 26155-07
