removing bat wing fairing
Old 09-07-2006, 03:46 PM
cantdecide's Avatar
cantdecide
cantdecide is offline
Default removing bat wing fairing
How hard is it too remove the fairing on an electra glide ultra classic. I want too install my XM radio & need to remove the fairing....
Old 09-07-2006, 03:48 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
AK_Hog_Herder is offline
Default RE: removing bat wing fairing
Seven torx screws, disconnect the headlight, you're done.
Old 09-07-2006, 03:49 PM
MACK's Avatar
MACK
MACK is offline
3 SCREWS ACROSS THE WINDSHIELD AND 2 EACH ON LEFT AND RIGHT SIDES OF INNER FAIRING. DISCONNECT HEADLIGHT. THATS IT
Old 09-07-2006, 03:59 PM
zubaugh's Avatar
zubaugh
zubaugh is offline
I place a towel on my front fender and lay the passing lamps on it.
I've been wanting to go with XM but still want the controls to function. Are you upgrading to an 07 HD radio or do you know if that's possible?
Old 09-07-2006, 04:27 PM
Bigredone's Avatar
Bigredone
Bigredone is offline
Put socks on your passing lights. A couple of the screws are well hidden. Don't get in a hurry.
Old 09-07-2006, 05:52 PM
bradteed's Avatar
bradteed
bradteed is offline
Be careful with the lowest screws, they are back behind the forks and if you drop one, they tend to get caught between the fork and the inner fairing.
I would also suggest that you loosen (not remove) all of the screws...and then slowly take out the top...ensuring that you have a good handle of the windshield. If you don't, sometimes the tension on it will cause it to pop out and get scratched.
Old 09-07-2006, 05:58 PM
harley0711's Avatar
harley0711
harley0711 is offline
remove the top windshield screws (put the middle screw in about half way to hold everything)... then remove the rest (you do Not have to remove the passing lamps) it will go on and off with them in place,,,, like said, take your time - the sock idea is a good one - once you have done it - you will see just how easy it is.... be glad you do not have a RG
Old 09-07-2006, 06:50 PM
Bigredone's Avatar
Bigredone
Go to this link. Excellent guide: https://www.hdforums.com/m_384080/tm.htm
This was also posted earlier:
Using a Torx 27, remove the 3 screws under the windshield and remove the windshield. From the other side, remove 2 screws (1 each side) by the hand grips. Now, turn the bars full left and on the right side near the neck, remove 1 screw. Then full right and remove the left side screw. Lift up and forward and unplug the headlight. Lift off fairing.
benningtonr
2014-2023 Touring Models
19
02-22-2017 11:12 AM
carcass
07-02-2010 06:20 AM
bulldawg10
10-19-2009 08:34 PM
Softtail Bob
05-04-2007 12:27 PM
cemax12000
05-18-2006 04:08 PM
Quick Reply: removing bat wing fairing
