Help - floorboard extender bolt broke
Old 08-31-2010, 12:28 PM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
drill into it with a bit about half the size of the bolt diameter then try an easy out(screw extractor). Best to start small just in case it doesn't work the first try you can drill a little bigger and you don't get into the threads. Take your time it can be an aggrevating job removing broken bolts. Lesson learned, if it seems like it shouldn't be that hard, then it probably shouldn't. Good luck.
Old 08-31-2010, 01:10 PM
cass's Avatar
cass
cass is offline
went up to ace and got a drill bit and extractor. will set up the jackstand and give it a go. appreciate all the advice. tom, appreciate you jumping in. will get back to you after a bit. I picked up a couple of bolts while up at ace so thats no prob. gonna move her up on the deck where i can be in the shade and take my time. Appreciate the tip about the compressed air. will give it a try. Will let you know how it goes.
cass
Old 08-31-2010, 02:41 PM
frog13's Avatar
frog13
frog13 is offline
You did make sure you got Grade 8 or better bolts, correct? If not, you are in for another surprise in the future ..........
Old 08-31-2010, 02:53 PM
2011 Road Glide Ultra's Avatar
2011 Road Glide Ultra is offline
As far as the cruise control, the switch is sold by itself. Had one go bad on my '07 four days into a three week trip last year, and got an upgraded (and more $) one to replace.
Old 08-31-2010, 05:15 PM
cass's Avatar
cass
cass is offline
Well, not much progress. I used a real fine drill and was making some progress, then the drill snapped off inside the hole. if it weren't for bad luck I'd have none at all on this job. went up and bought a couple of new carbide drill bits....not even scratching it from what i can tell. guess i'll have to wait until tomorrow and see if i can pick up somethng stronger than the carbide drill.
cass
Old 08-31-2010, 05:32 PM
Wassup8687's Avatar
Wassup8687
Wassup8687 is offline
You may want to go to an Indy or a dealer and see if they can get it out. Did you try PB Blaster or WD 40?
Old 08-31-2010, 06:21 PM
slack20's Avatar
slack20
slack20 is offline
i ran a thread chaser through the holes first and a dye on the bolts when i installed mine they started goin in real tight so i backed them out tapped-dyed problem solved
Old 08-31-2010, 06:47 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is online now
Originally Posted by jvvjvv
I had to run a die over a couple of the bolts supplied with the kit..........TOO much plating.
Not necessarily.
The fastener threads being used for plating should be made smaller/larger to allow for plating build up.
Companies producing these chrome fastners should be using thread gages to check the finished product.
Old 08-31-2010, 06:54 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Originally Posted by 1FLTRI4ME
Not necessarily.
Yep, Your right, with a good quality chrome bolt You will not have any problems............To the OP, Glad it did'nt break during a ride, which could have been nasty.
Old 08-31-2010, 06:56 PM
1flhtk4me's Avatar
1flhtk4me
cass
A solid carbide drill should drill it,but very likley to break if drilled by hand.If it does break,you can chip it out.
Quick Reply: Help - floorboard extender bolt broke
