wobble advise needed
Old 09-09-2010, 08:48 PM
missouri traveler's Avatar
missouri traveler
missouri traveler is offline
2nd Gear
Default wobble advise needed
hey, have a 2000 ultra 27000 miles with a lot of wobble in bike in the corners. looking at progressive shocks, touring link, glide pro stabilizer system, velva ride. i need advise on where to spend money first.
Old 09-09-2010, 09:19 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
You need one of the stabilizers, first.
Check out the Progressive...it's about the cheapest out there.
They all do the same thing.
Old 09-09-2010, 09:47 PM
SteveO's Avatar
SteveO
SteveO is offline
It's the shocks. Go with the Progressive you won't believe the difference in handling !!
Old 09-09-2010, 11:20 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
Have your swingarm bushings replaced first, before any "patches". Then a stabilizer could be added if you want.
Mark
Old 09-09-2010, 11:47 PM
SofaKing's Avatar
SofaKing
SofaKing is offline
Stage II
Low mileage for a 2000, anyway I installed the Glide Pro bushings in the back of my 08 FLHX and noticed dramatic improvement. If you watch his video pro-mo it explains itself. If your going after the swing arm bushings (good place to start) these are pricey but the best IMO, and a good investment for future improvements.
Old 09-10-2010, 03:26 AM
Sooner's Avatar
Sooner
Sooner is offline
5th Gear
If you add a stabilizer check out the Bagger Brace. Great quality and a pretty simple installation.
Old 09-10-2010, 03:04 PM
MyFirstHD's Avatar
MyFirstHD
MyFirstHD is offline
What kind of wobble, high speed or low speed turning into the driveway?
Old 09-10-2010, 03:43 PM
harry.b's Avatar
harry.b
harry.b is offline
If I had a new wobble, the first thing I would do is check the tires for cupping. It happened to my other bike and I had a wobble going around corners. Checked the tire and sure enough looked like a roller coaster ride on the left side of the front tire. New front tire and wobble is gone. Tires can cup on harleys too (obligatory HD forum statement).
Old 09-10-2010, 05:24 PM
rdoucet's Avatar
rdoucet
rdoucet is offline
Had same issue on a 2004 Ultra; tire air pressure too high first of all so set to what service manual said. Problem better but not great so I installed the bagger brace and it made a huge improvement. Not endorsing any specific product, I just bought the above brace based on other peoples input.
Old 09-10-2010, 08:57 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,619 Likes on 2,094 Posts
See this thread and check your swingarm.
https://www.hdforums.com/forum/gener...-swingarm.html
Quick Reply: wobble advise needed
