07 Ultra Starter Problems
Old 09-11-2010, 12:37 AM
texasmail1962's Avatar
texasmail1962
texasmail1962 is offline
Smile 07 Ultra Starter Problems
Just about everytime I start my bike it sounds like the starter is grinding the gears instead of turning anything. It does the kickback thing also. Did a search on the forum, think I found my problem. It needs a new compensator. Beleive I should get the SE compensator. Is there any thing else I should look at?
I am wondering how hard of job is this to replace. I have service manual.
Thanks for the help!!
Old 09-11-2010, 12:52 AM
trackadaptor's Avatar
trackadaptor
trackadaptor is offline
Cool
Nope: Starter Clutch
http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
Not sure why / how anybody would think compensator ???
Originally Posted by texasmail1962
Just about everytime I start my bike it sounds like the starter is grinding the gears instead of turning anything. It does the kickback thing also. Did a search on the forum, think I found my problem. It needs a new compensator. Beleive I should get the SE compensator. Is there any thing else I should look at?I am wondering how hard of job is this to replace. I have service manual.Thanks for the help!!
Old 09-11-2010, 04:10 AM
tjmac49's Avatar
tjmac49
tjmac49 is offline
texasmail1962: Have you checked the starter's mounting bolts? More common of a problem than most know. There is a Technical Service Bulletin on that issue (M-1231 dated September 26, 2008). I can't upload the pdf file for you because of the file's size. Search this forum; it has been discussed before.
Old 09-11-2010, 07:43 AM
texasmail1962
Yes I have checked them. I have the service bulletin.
Old 09-11-2010, 07:55 AM
smokindave's Avatar
smokindave
smokindave is offline
Just do a poll asking the thousands here on the forum who have changed to an SE comp what they think. Also why do you think the MOCO has put the SE comp on all new 11' bikes? Hopefully the OP hasn't already eaten up his ring gear or starter gear.
Old 09-11-2010, 10:18 AM
trackadaptor
Cool Poll
Ok started a Poll .....
Old 09-11-2010, 03:38 PM
brogers's Avatar
brogers
brogers is offline
I just brought my bike in last week for the same thing thinking for sure I needed a new compensator. They said no it is the starter drive so I had them put one in and that was the problem, now it starts just fine. I was almost disapointed I wanted an excuse to put in the S.E. compensator
Old 09-11-2010, 07:12 PM
texasmail1962
I took my starter off and the pinion gear looks bad. Looks like its been grinding instead of engaging. Guess I will replace the starter drive clutch first.
Old 09-11-2010, 07:34 PM
stro1965's Avatar
stro1965
stro1965 is offline
I'm one of the few who installed the SE Comp and found very little, if any, benefit. I still get hot start kickbacks.
Old 09-11-2010, 07:46 PM
greg09997's Avatar
greg09997
greg09997 is offline
This was the solution for my bike. No problems now.
c50plus
09-06-2012 08:22 PM
stro1965
07-06-2012 08:47 AM
mps1168
08-05-2010 07:17 PM
Topspin
01-02-2008 09:49 PM
Topspin
12-31-2007 04:07 PM
Quick Reply: 07 Ultra Starter Problems
