SE compensator kit stator rotor
I installed a SE compensator on my ultra. Managed to allow one of the springs slip behind the shaft extension. BIG mistake, rotor shifted, ate the stator and magnets managed to get the old one back together and replaced the stator but I'm at a a loss to find a replacement rotor. The dealers vie spoken with can't sell them independently. Any suggestions as to where I might find a replacement rotor (stator housing)
Thanks,
Whiskey
Thanks,
Whiskey
expensive
It's a mistake that will just about double the cost of the upgrade. I found the part number SE 30041-08 for the rotor ($110 from HD) and another buck and a half for a new stator. And throw in another ten bucks for the shattered thrust washer. My $250 upgrade is creeping up into a $600 PIA. Not quite what I would have paid to have the repair done at the shop but damn close enough. This damn well better take care of that front end primary case noise.
I don't know if the instructions have changed over the last few years, but mine states clearly to watch the springs getting trapped behind other parts, hence the wisecrack. I was so worried when I finally fired her up, because you really cant tell until it's too late. Although I checked and re-checked 3-4 times before I torqued the bolt down!
