Fuel Pack VS Screaming Eagle Street Performance Tunermance
Trying to get some feed back which would be the better way to go. I have a 2010 Electra Classic and the mods to include Screaming Eagle Stage 1 Air Cleaner Kit, Fullsac Ceramic X-Pipe Header and Widow Slip On Mufflers.
Thanks
Jerry
Thanks
Jerry
You may get lots of opinions on this one but I'd say neither. The V&H Fuel Pack has very limited tuning ability for future mods such as cams. SE stuff you have to rely on dealer downloads. I went with the PCV & auto tune from Fuel Moto with one of their canned maps. Extended warrenty from Fuel Moto & lifetime support. Change cams, pipes, A/C, do a BB kit? Call Jamie & get a new map. If cost is a factor you can just get the PCV & add auto tune later if you want. His canned maps work well, maybe not as well as a good dyno tune but, I'd rather run rich & cool than lean & hot & all I'm losing is a few mpg. Just my
All have followers and haters. The best is with a competent dyno tuner and his software of choice - SERT, SEPST, TTS MasterTune. Some even dynotune PCVs.
The next step down is a PCV A/T. Below that is PCV, Fuel-pak and dealer download.
Finding a competent dyno tuner is not easy or cheap, but I believe it is the best way.
