Fast idle at startup?
The issue...every once in a while when i start the bike, the idle will be up around 2000rpms. Sometimes it will be normal, but as soon as i pull in the clutch the rpms will jump to 2000. If i let the clutch out slowly, the rpms drop to normal but if i start to pull the clutch in again, the rpms jump back up to 2000ish. I had read some where that when that happens, if you just stand there with the clutch pulled in and twist your bars all the way left then all the way right the idle will drop down to normal rpms. That is what i do every time it happens and the bike is fine after that. It did it stock and with the PCV, so i don't think it's the ecm. I've been getting in the habit of always twisting my bars back in forth before i take off, but it is annoying. Anyone else have this happen and have a real fix for it?
Thanks.
Thanks.
Do you let your bike warm up? I'd be willing to bet it's just the ecm bumping the idle up a little because it's either cold or thinks it's cold. Remember chokes? The ecm is doing the same thing. Let it run a minute and I bet it will drop back to normal idle on it's own as it warms up and all the sensors are happy. Sometimes this will happen even if the bike is warm but once the sensors realize everything is ok, then your idle should settle on it's own.
If swinging the bars back and forth is really effecting your idle speed, you have more issues than you think.
On 2008 bikes if you shut the bike down using the kill, switch while the throttle is partially open, it will reset the "zero" on the throttle.
(That is you accidentally twist the throttle a little when you reach for the button with your thumb).
To reset it cycle the ignition switch (off to run then back to off) 4 times waiting a few seconds at each position.
I'm not sure if this is true for other years.
Skye120 (05-26-2020)
When the same thing happened to a friend of mine he thought that I was a real bright guy for having a ready solution...
Impala_ss
09-17-2015 07:51 PM
