EZ-Up Center Stand vs. Harley Center Stand (PN 91573-09A)
Old 10-05-2010, 02:17 AM
StanfordMan's Avatar
StanfordMan
StanfordMan is offline
Default EZ-Up Center Stand vs. Harley Center Stand (PN 91573-09A)
I know that the EZ-Up Center Stand is very well liked on this forum; but I was wondering if anyone has comparison information on the Harley Chrome Center Stand? Aside from the price difference (the EZ-Up is easier on the wallet), is there a marked difference between the two?
Old 10-05-2010, 06:34 AM
wingman05's Avatar
wingman05
wingman05 is offline
EZ-Up will not lift the rear wheel off the ground for maintenance and cleaning. They say put a piece of 3/8 inch plywood under the legs and you will lift the rear wheel. The HD Center stand legs can be adjusted to lift the rear wheel off the ground. I had the HD on my 08 Ultra, and will shortly have one on my 10 Ultra limited.
Old 10-05-2010, 10:18 AM
StanfordMan
Wingman, how easy is the HD Center Stand to use? The EZ-UP stand apparently is very easy to get the bike on and off the stand. Thanks.
Old 10-05-2010, 10:32 AM
TXCOMMISH's Avatar
TXCOMMISH
TXCOMMISH is offline
I use the Easy-up stand and I love it. No it is not adjustable, but, it is built solid as a rock! When I want to clean the rear wheel, I just slip a little piece of 1/2 inch board under the stand and raise the bike up. Easy peasy-lemon squeezy. Plus, the Easy-up people are great to deal with and not at all like the "you owe us" Harley dealer folks.
Old 10-05-2010, 11:41 AM
gunnut1's Avatar
gunnut1
gunnut1 is offline
I saw a guy use the HD recently and it worked great and he said that he liked it, however he said that you could not use it with the HD premium oil cooler.
Old 10-05-2010, 12:03 PM
relli's Avatar
relli
relli is offline
cant say enough bout the Easyup. draws alotta inquiries when people see how easy it goes up or down
Old 10-05-2010, 12:09 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
The HD one is adjustable, so if you've changed either the front or back rim you will need it adjustable.
Old 10-05-2010, 03:47 PM
vistavette's Avatar
vistavette
vistavette is offline
I just installed an EZ-UP on my 2009 Ultra this weekend and so far I love it. I put a piece of 3/8 plywood under it to clean the rear wheel and check the air pressure. I also did an oil change and clutch adjustment. What an easy job with that stand. The best part is that I don't have to get off the bike to get it on the stand; its just so easy to use.
Old 10-05-2010, 04:15 PM
TooEasy's Avatar
TooEasy
TooEasy is offline
Could I use my J&S jack with either one of these stands? Or does the mount interfere with the use of the jack?
Thanks,
Old 10-05-2010, 05:10 PM
'05Train's Avatar
'05Train
'05Train is offline
I can't speak for the Harley stand, but you have to remove the EZ-Up to drain the transmission. If you don't, the fluid goes everywhere.
Quick Reply: EZ-Up Center Stand vs. Harley Center Stand (PN 91573-09A)
