front brake lever rattle
if you're curious about your wiggle in your clutch or brake lever, look in your service manual. in there you'll find a parts breakdown and it shows the part in there. easy to fix as long as you remember that the brake light switch is operated by the front lever too and take the proper measures to avoid damaging the plunger. there is a correct procedure for that.
