Found them on ebay for $99. There were some for a bit more and they looked a bit better....I was thinking about the one that is mounted on the Tri-Glide.
Trikes have handling challenges, as they obviously don't lean in bends. If you experience any frontend action it probably starts at the rear of the bike. Before you spend any money check the basics on your bike, such as head bearings are adjusted right, tyres are in good condition and pressures correct, alignment, etc.
You can improve your ride with better tyres, such as Avon Venoms, which give improved comfort and handling, also stability. If you are happy that all is OK consider a stabilizer kit such as True-Track. I have them on my Glide and Dyna and they have transformed both bikes.
I have considered the true track but have heard so many different opinions...I think i will start with the neck bearings... I am putting a new tire on this weekend...went with the Pirelli Night Dragon this time...
I have the one from BK-Rider. works great. The one fro the tri glide won't work. Tri glide trees have more rake, it won't fit on an o8 street glide, not enough room.
I just bought one for My Ultra, How do they bolt on???.
If you have crash bars, remove the top bolt to the frame and install the new tab there. Big plate mounts under the lower tripple tree. The damper will point forward under the headlight. If you need pix let me know.
