Splash Back When Refuelling 6 Gallon Tank
I just upgraded from a 2007 FLHTCU (5 gal tank) to a 2011 FLHTK (6 gal tank). I notice a lot of splash-back when I refuel, due to the new design of the filler neck. No matter what I do or where I get gas, the result is the same. I have tried using the minimum pressure possible on the nozzle trigger but no joy. Also, it seems like I need a bazillion small squirts when its nearly full, just to top it off. With the '07, it was pretty easy to do it in one go.
Anyone else experience this? Anyone have a solution?
2010 RK 6 gal tank... no issues with either... but Calif has those stupid boots around the nozzle. To top off, I simply hold the boot up with one hand, put the nozzle just past the inside collar, don't squeeze the handle all the way... flows continuously until I stop it. Been that way for my two previous bikes as well.
I hate splash back! Has any body tried this item? http://www.harley-davidson.com/gma/g...bmLocale=en_US If it works, it worth every dime.
Ride safe,
Bob.
Ride safe,
Bob.
I've got one of those, and notice it works the same on the new SG's tank as it did my softail and the wife's dyna.
That is, it either works fine or not at all....depending on how far you compress those silly boots down.
Compress it all the way, works like a charm.
Compress it just enough to let you start filling up, I get splashback.
Best thing is like they say: don't squeeze the handle to "full speed". Just enough to flow slowly, and it won't be a problem.
My biggest problem is the flip-up cover plate and getting a good angle. I ended up automatically going with holding the whole thing upside down and using the funnel thing, which I now keep in my saddlebags all the time.
Ride safe,
Bob.
Ride safe,
Bob.
The McCuff aleviated both of these problems, and also avoids any scratches you get around the gas hole from the boot.
I reccomend it to any one. the space between the boot and actual fill spout allows you to fill your tank up to the exact point where the fill cup inside the tank is. <---- don't know if i explained that right.
and as an earlier post mentioned you have to be sure to compress the boot completly and use the slow setting of the gas fill.
I have an H-D version of the McCuff. I started using it with the 2007 FLHTCU. Eventually, I figured out that the secret behind it was that it acted as a spacer, just keeping the nozzle high enough that you get a full fill when the nozzle clicks. I then figured out how high the nozzle has to be and then went without the McCuff. I'll start using the McCuff again and see how things pan out.
