2010 road glide rear lights not working
Old 10-23-2010, 06:23 PM
kildar's Avatar
kildar
kildar is offline
Default 2010 road glide rear lights not working
I pulled my rear light bar off to re powder coat it and after reassembly the brake lights work and the turn signals work but the license plate light and light under the fender stopped working. I checked the fuses and all are good there. Any ideas help is much appreciated.
Thanks,
Tim
Old 10-23-2010, 06:30 PM
leohd's Avatar
leohd
leohd is offline
Tim, I think its something you messed up lol
Old 10-23-2010, 06:58 PM
gmc's Avatar
gmc
gmc is offline
Are your front turn signals on as running lights, if so it in the back wiring naturally. If not replace the light fuse even thought it may look good. If it blows you might have pinched a wire.
Old 10-23-2010, 07:25 PM
kildar's Avatar
kildar
kildar is offline
Ha...Thanks Leo.
Yes the fronts are working as running lights. I installed custom dynamic leds direct wired to the purple, blue, and black. I used them this way instead of using the actual plugs. I was still having the the issue using just regular bulbs. My guess is it has something to do with the way I reinstalled the light bar.
Old 10-28-2010, 07:11 PM
kildar's Avatar
kildar
kildar is offline
Well I figured it out. I had to disassemble the fachia light at the rear and found that the o/w wire going to the light had lost power somewhere on the circuit board. I just decided to add a jumper wire from the o/w wire to the red wire going to the light and wolla....light.
Old 10-28-2010, 07:59 PM
leohd's Avatar
leohd
leohd is offline
[QUOTE=kildar;7467193]Well I figured it out. I had to disassemble the fachia light at the rear and found that the o/w wire going to the light had lost power somewhere on the circuit board. I just decided to add a jumper wire from the o/w wire to the red wire going to the light and wolla....light.
and they said let there be light and there was .....
FFLETCHER
09-11-2012 07:07 PM
burningvegas
07-09-2012 04:25 AM
flatsix
03-15-2012 07:02 AM
edfromptowne
10-25-2009 07:39 PM
frenchbiker
07-04-2009 08:39 AM
Quick Reply: 2010 road glide rear lights not working
