2011 103 loud compensator.
I am lucky my 2011 RGU is incredibly quiet. I have never been around any harley that has so little mechanical noise. I hav e 3500 miles and it is uncanny I think maybe it was built by BMW or something. I changed oil today and went with synthetic V-twin 20-50 so maybe that will noisy things up a bit. This is the 4th oil change and have been using Valvoline 20-50 dino. not a speck of anything in the filter or on the drain plug magnet.
If it's going out, you should hear a loud clank (not clunk like stock) during starts. And you can really feel it during hard launches. Feels like the belt is slipping on the sprocket. If you feel that, get it checked immediatly because you can tear up the starter clutch, which will double the cost of the fix. I have the t-shrt.
Beary
Beary
Humm I have that same issue on my 96" thinking it might be the cam chain....didnt think neutral rattle was an issue with newer bikes? Only does it when starting out before it gets completely warm and after a cool down from a break. It would set my mind at ease if it is a neutral rattle. I put a richer map in it awhile back and it quitted my valve train noise to the point that it sounds like my brand new FXDC, a wrench told me its because of the richer map....?
2011SuperGlideMarine
06-19-2012 02:20 AM
