Heated Grips Info
Heated Grips Info
I stopped by my local Harley Dealer today to replace a light bulb in my tour pak of my 2011 Ultra Limited (hard to believe a bulb was already bad). I mentioned to the mechanic about how the heated hand grips seem to be hotter on the right side. He showed me an article in the HD "Shop Talk" pamphlet which dealers get. This issue had info on heated hand grips.
Of interest which I read was:
1. Heated hand grips can take up to 20 minutes to reach the selected heat. Ambient temperature and humidity are players in this.
2. Heated hand grips heat up from 135 - 170 degrees F.
3. The right grip throttle has more material for the heat to transfer thru.
4. The left grip is where the thermostat is. Also if you remove your hand from the left grip, the thermostat thinks it needs to heat up so if your right hand stays on the grip, it will get hotter.
5. 53% of heated grips replaced are actually functional.
There was more info about this but this is what I really recall the most. The info I read was very educational regarding heated hand grips. I've gone thru 4 sets and learning how they operate is really an eye opener. So if you have heated hand grips I recommend asking the service department to let you read this "Shop Talk" issue.
I really think they should explain how the grips work.
Well, I found it interesting. Hope this is somewhat informative.
Cheers and Happy Riding.
Thanks for this info. My wonderful wife presented me with an early Christmas present yesterday, heated grips which I will have installed tomorrow. We live in Connecticut and it is getting cold, but my wife likes riding with me even in the cold. It was only my hands that were getting cold and hope this really extends my riding season. This weekend we are riding to Newport, Rhode Island and I am really looking forward to seeing how these heated grips work.
Do the 2009 Ultras already have the wiring in the handlebars? That would simplify the install.
Interesting... Thanks for the data. The heated grips on my 2010 Limitied are working fine and I have already used them several times. Just FYI... my left grip seems to be warmer then my right grip but it's no big deal. They really help make early morning rides in the fall and winter pleasurable.
Thanks for the info.
I rode most of my life without heated grips, then along comes the new ride with this added extra attraction. Nice to have, but . . .
My '10 LTD is on it's second set. First set never really worked consistently, then not at all. When they were replaced I spent some $$$ and had the Rumble collection installed. (CVO's) They are comfortable and I like the look, but $$$, damn. Not real happy with these either, they work but don't seem to get near as warm as the stock set did. (when they worked) The stock set would get so warm that you could not bare hand the grips at a setting of 4 or above. I also notice the phenomenon of left warmer then right. The new set seem to work best at a setting of 4 or 5, high (6) seems to drop off temp.
